| a-spec racing ek subframe reenforement kits. https://thejdm.com/forum/viewtopic.php?f=20&t=2988 |
| Author: | .saint [ February 09, 2005 ] |
| Post subject: | a-spec racing ek subframe reenforement kits. |
check em. im getting the racing package later on this summer... they also just put together some for the EG. [center:05b985ca7d]96-00 (ek) subframe reinforcement brace package [/center:05b985ca7d]Strengthens your subframe, preventing it from tearing behind the mounting hardware of a large-diameter swaybar by enlarging the contact region between the two as well as limiting torsional force on the subframe sheet metal. use a variety of swaybars. completely bolt-on. features + ASR 6061-T6 aluminum subframe reinforcement bar + 6061-T6 aluminum support plates + Installation Hardware + Installation Instructions [center:05b985ca7d]96-00 (ek) subframe brace + swaybar complete kit [/center:05b985ca7d]A complete package that has everything you need. It includes the subframe brace and all swaybar hardware. 2 types of endlinks are offered as an option, stock Honda endlinks and Aurora Teflon endlinks with spacers. features + ASR 6061-T6 aluminum subframe reinforcement bar + 6061-T6 aluminum support plates + OE Acura Integra Type-R 22mm swaybar + Aurora Teflon-coated or Honda OE endlinks (your choice) + 6061-T6 aluminum control arms + Installation Hardware + Installation Instructions [center:05b985ca7d]96-00 (ek) subframe brace + 32mm swaybar racing package [/center:05b985ca7d]The ultimate swaybar setup for your EK! This package includes an enormous 32mm hollow shaft swaybar and our patented subframe reinforcement bar. Track tested to neutralize understeer. This system is 100% bolt-on. Please note that this reinforcement bar is custom-drilled for new subframe mounting locations, and will need to be uninstalled to mount a swaybar in the stock location. features + ASR 6061-T6 aluminum subframe reinforcement bar + Hollow 32mm (2.41mm wall thickness) swaybar + Teflon-coated rod ends + 6061-T6 aluminum control arms + 6061-T6 aluminum support plates + Installation Hardware + Installation Instructions |
| Author: | munster [ February 09, 2005 ] |
That's rad. |
| Author: | Sean @ NDF [ February 10, 2005 ] |
BAM! good find... |
| Author: | eckoboy008 [ February 16, 2005 ] |
That shit is sick!!! |
| Author: | .saint [ February 16, 2005 ] |
i havr the srr setups as well... im keepig the purple lca's but im selling the sway and tie combo. |
| Author: | jag. [ February 16, 2005 ] |
wow, that stuff looks hot! |
| Author: | JaySmith [ February 17, 2005 ] |
Very interesting.... I would like to see some daily driven results before I actually purchase it though. And do you guys already have, or plan to get a front sway bar? |
