a-spec racing ek subframe reenforement kits.
Post by .saint » February 09, 2005
check em. im getting the racing package later on this summer...
they also just put together some for the EG.
[center:05b985ca7d]96-00 (ek) subframe reinforcement brace package Image[/center:05b985ca7d]
Strengthens your subframe, preventing it from tearing behind the mounting hardware of a large-diameter swaybar by enlarging the contact region between the two as well as limiting torsional force on the subframe sheet metal.
use a variety of swaybars. completely bolt-on.
features
+ ASR 6061-T6 aluminum subframe reinforcement bar
+ 6061-T6 aluminum support plates
+ Installation Hardware
+ Installation Instructions
[center:05b985ca7d]96-00 (ek) subframe brace + swaybar complete kit Image[/center:05b985ca7d]
A complete package that has everything you need. It includes the subframe brace and all swaybar hardware. 2 types of endlinks are offered as an option, stock Honda endlinks and Aurora Teflon endlinks with spacers.
features
+ OE Acura Integra Type-R 22mm swaybar
+ Aurora Teflon-coated or Honda OE endlinks (your choice)
+ 6061-T6 aluminum control arms
[center:05b985ca7d]96-00 (ek) subframe brace + 32mm swaybar racing package Image[/center:05b985ca7d]
The ultimate swaybar setup for your EK! This package includes an enormous 32mm hollow shaft swaybar and our patented subframe reinforcement bar. Track tested to neutralize understeer. This system is 100% bolt-on. Please note that this reinforcement bar is custom-drilled for new subframe mounting locations, and will need to be uninstalled to mount a swaybar in the stock location.
features
+ Hollow 32mm (2.41mm wall thickness) swaybar
+ Teflon-coated rod ends
Post by munster » February 09, 2005
That's rad.
Post by Sean @ NDF » February 10, 2005
BAM! good find...
eckoboy008
Post by eckoboy008 » February 16, 2005
That shit is sick!!! :eek: Makes me want to get rid of my SRR sway kit. I'll still keep the Purple rear arms though. 8)
Post by .saint » February 16, 2005
eckoboy008 wrote:That shit is sick!!! :eek: Makes me want to get rid of my SRR sway kit. I'll still keep the Purple rear arms though. 8)
i havr the srr setups as well... im keepig the purple lca's but im selling the sway and tie combo.
jag.
Post by jag. » February 16, 2005
wow, that stuff looks hot! :) if it works as good as it looks, would be cool setup :)
JaySmith
30% JDM
Post by JaySmith » February 17, 2005
Very interesting.... I would like to see some daily driven results before I actually purchase it though. And do you guys already have, or plan to get a front sway bar?
