Coilovers??
tein flex owns that statement.munsterEK wrote:Personally I don't like sleeved coilovers. You take away from the ride quality of the springs when you adjust them to lower the car. Sure low springs will ride rough too, but at least the springs were made to ride at that rate. coilovers you're just smashing the spring.
...if that post made sense? haha.
-lowhatch52-
- 100% ricer
no, actually with coil overs..you are compressing the spring because in order for you to get the low height that you want you have to crank it up making the spring smaller and stiffer.kotomile wrote:Munster, you're not compressing the spring when you lower the coilover, you're only moving it vertically about the shock, no harm in that.
Yea, the perch on skunk2's doesnt have a flange, it just ends with the threads. Man getting the perch out of the shock is a bitch! once you get skunk2's installed on a shock try to keep them on that shock because it's hard as fuck to get out. I think skunk2's would be real good for the track since they're kinda stiff (i wouldnt know though still have stock motor) but for daily driving it gets annoying sometimes. I personally wouldn't go with a sleeve type set up ever again. I'd just like one unit like Tein. for 100 bucks more I could've gotten Tein Super streets. I wouldn't go cheap on suspension, get rota's or fake oem shit for exterior I guess, but suspension is important especially for daily driving.wouldyoupleasedie wrote:i heard on the kunk2 coil overs there is like a little flang on the bottom of mosts coil overs that usually sit down on the shock tower. and the skunk2 dont have this flange. witch isnt nothing major. i just heard sometimes they squeek a little if u hit a bump thats pretty big. i dont know if this is true i never owned a set or anything but this is what i was told from a local shop. :shrug:
