cars not workin
tomoyasu
cars not workin
Post by tomoyasu » January 13, 2008
i gots electrical power, but the engines not turning over at all. thought that it could be a loose ground or something, but after tightening everything down still no juice. any suggestions on what it could be? starter?
Post by Nikku » January 13, 2008
i would check that first if its not turning over.
Post by .saint » January 13, 2008
yeah i was gonna say ground when i read the thread but if you checked them i would say starter.
Teaks92HB
Post by Teaks92HB » January 14, 2008
little ground on starter? any fuses? after market ignition? ecu?
EG2sol
70% ricer
Post by EG2sol » January 14, 2008
Try the main relay and I think there is a fuse for the starter you could also look at
tomoyasu
Post by tomoyasu » January 15, 2008
Teaks92HB wrote:little ground on starter? any fuses? after market ignition? ecu?
actually, that one was loose. the guy i got the car from put another ground from almost the same spot...do i need it? No fuses are blown, stock ignition...not sure about the ECU
Post by Nikku » January 15, 2008
definately check the main relay. those things go bad on EFs all the time and they can cause the exact symptoms you are having.
Post by tenchu » January 15, 2008
You try push starting it (if its manual?) my EF wouldnt start one day and I push started it and after that its never had a problem starting (weird)
tomoyasu
Post by tomoyasu » January 25, 2008
yeah i am able to push start it. had my battery checked and it had no cold crank amps* which are needed to turn it over. got a new battery, still no worky. as soon as i get some money ill slap a new starter in.
Natural Aspirations
55% ricer
Post by Natural Aspirations » January 25, 2008
Check for voltage at the starter with the ignition turned to start. Damn you guys .......
