Head Gasket ?
- boostjunkie95
Head Gasket ?
Ive seen quite a few builds where people are using oversized head gaskets, usually .5mm bigger then their bore. Are there any advantages in doing this? Just curious why they wouldnt use one that is the same size as the bore.
- Secret Squirrel
using a bigger headgasket serves to purposes.
1. they had the block or head, or both machined, and the thicker HG is to compensate for that.
2. Changing HG size can vary compression ratio. So for example, a 1.2mm hg gave a 8.5:1 comp ratio and a .9mm HG gives a 8.2 compression ratio. **this is ficticious numbers**
- boostjunkie95
- Secret Squirrel
