rpm's ^^^^
https://thejdm.com/forum/viewtopic.php?f=17&t=7110
Author:  98or00gsr [ September 14, 2006 ]
Post subject:  rpm's ^^^^
i have a 1997 (i dont know the xact year for sure.. i bought it from hmotors but it is obd2) b18c (not a type r its a jdm gsr) and i have a skunk2 intake manifold on it and tried to put a skunk 2 throttle body on it and after the install i started it up and the rpm's shot up really fast.. i dont no if that one just didnt fit or what.. but what im askin is do u no if know if you are suposse to put a certain throttle body on that motor.. or i most likly just had a gap somwhere on the throttle body when i installed it and a small air leak could cause that to happen.... and also what size throttle body would u suggest for my motor i will put up a list of mods below in case you need to know that stuff.. i am wantin to build it all motor also... ? thanks alot
b18c (jdm gsr)
apexi gt header
aem cold air intake
tanabe medallion full exhaust w/ skunk2 test pipe
this is the stuff that prolly doesnt matter
type r radiator
skunk2 short shifter
nology hot wires
act street/strip clutch
civic type r ecu... kindda wantin to sell or trade for gsr ecu
thanks again for any help u can give me
Author:  munster [ September 14, 2006 ]
Check all of your vac lines. Was everything hooked up on the intake manifold that was on the stock one?
Author:  98or00gsr [ September 15, 2006 ]
yes, everything was hooked up on the manifold... bcuase i had the manifold hooked up the day before i tried installin the throttle body... but im pretty sure that the throttle body just wasnt prefectly set up againt the manifold cuzin it to leak a bunch of air and cuasing the rpms to do that.. but my new question is do i really need a throttle body ? i wantin to go all motor.... do i relally need to buy a throttle body now or can i still upgrade my cams and vave train w/ out a throttle body... thanks
Author:  vtecdood [ September 15, 2006 ]
throttle cable is ok? when going to the skunk 2 on the gsr you need the typer throttle cable and bracket if you dont have this it might be adjusted to far and holding the throtlebody open.....
