header question
01teggy
header question
Post by 01teggy » June 12, 2006
does anybody know of anyone who has tried the blox header? if so is it similar to the skunk header? any complaints or compliments about the blox header would help. :?
can i get xtra mater on that!!!!!!!!
vtecdood
Post by vtecdood » June 13, 2006
I know the blox intake is an exact copy of the skunk looks like they are from the same cast literally so my guess would be this is true for the header as well. Blox has good quality
Post by Sean @ NDF » June 13, 2006
I'm with vtecdoodoo on this one
Post by .saint » June 13, 2006
skunk2 was modeled after the ITR header so... save money and get oe ITR.
vtecdood
banzai wrote:I'm with vtecdoodoo on this one
you calling me a piece of crap? :x
vtecdood
.saint wrote:skunk2 was modeled after the ITR header so... save money and get oe ITR.
not to upset you but there really is not difference in type r to skunk or blox save the money go with the blox unless you are a jdm whore and need the Hype R factor :bang:
01teggy
Post by 01teggy » June 13, 2006
cool thanks guys!! :)
so any of you guys know anyone who tried the blox intake manifold? i heard it made good power but then you cant believe everything you hear, ya know
hahaha nah, jk
vtecdood
Post by vtecdood » June 14, 2006
01teggy wrote:cool thanks guys!! :)
If you are running a stock GSR manifold then you will see significant increase, with stock a LS or B16 not that much gain N/A, turbo depends on boost pressure 10psi or lower now anything higher than 10 id recomend it then or with an all motor build that has increased compression.
Post by Sean @ NDF » June 14, 2006
anyone wanna move this to engine tech?
