Guage cluster question
Hatcher
Post by Hatcher » February 13, 2003
When you do a swap, how will you pass SMOG if your mileage on the cluster has to match the miles on the motor? I always thought you could just adjust the miles on the cluster when installing one.
Post by .saint » February 13, 2003
i have a spoon cluster. they passed mine. they asked me if i rolled the milage back sicne last inspection i said i swapped out the entire cluster. then again i know the guys really well and they said 'looks cool' so hehe goto some1 you know well. or find a cluster with abot the same amount of miles. or you could always swap the odometers.
Post by munster » February 13, 2003
I put an EX cluster in mine, and I just swapped speedometers so I kept the same mileage.
I have heard of guys that just get something written up by a licensed Honda mechanic that says the car is legit after swapping out anything that changes the mileage. Call your local Honda dealership. Wow. I sounded like a commercial.
Hatcher
Any suggestions for what cluster I should get? Of course I cant get spoon since they're hard to find and $$$. Also when I call the local honda dealer, do I just ask to talk to the mechanics? people at the dealers don't know shit.
depending on what look your going with. if your swapped get an SI cluster cause the tach runs higher then an EX or something and if you want to spend a lil more money get a ctr cluster.
Hatcher
Yea I saw a ctr cluster on ebay a few days ago, I'm thinking about getting that one.
Can you guys explain to me how to swap out the odometer so I can pass smog? I'd appreciate it.
Like I said...I swapped the entire speedo since the color scheme was the same between my DX and EX clusters. Just that the EX had the tach. To swap the speedo was simple because it's just two screws. I'll tear apart my spare gauges tonight to see if I can get the odometer out. I'll let you know.
Ok. I just tore apart my spare cluster and had no luck getting the odometer out without tearing the speedo needle off. I don't know if anyone else here knows a secret that I don't...
Hatcher
Post by Hatcher » February 15, 2003
since ctr gauges are white, are they blue when your lights are on? those ones are kind of cheesy
Post by .saint » February 16, 2003
Hatcher wrote:since ctr gauges are white, are they blue when your lights are on? those ones are kind of cheesy
for the EK the ctr cluster has a black face with a carbon look surrond with amber lights. the EG faces are white with a black surround and amber lights...
the EK spoon cluster has a blue face with carbon look surround.
here is my spoon cluster to give you an idea of the colors
Image Image
