| stock LS rods n CTR pistons https://thejdm.com/forum/viewtopic.php?f=17&t=4845 |
| Author: | ismytaillightout [ October 07, 2005 ] |
| Post subject: | stock LS rods n CTR pistons |
would anyone sugest using stock LS rods wit CTR pistons if ur compression was around 12.3-12.5:1 on a ls/vtec setup? Do you think i would run into any problems? also the rods don't fit in the pistons should i get them machined down to fit (about 2mm off the rods) or just get neww pistons and if yes can anyone tell me where i can find sum rods that fit JDM ctr pistons that aren't that don't cost a arm and a leg? thanks |
| Author: | tenchu [ October 08, 2005 ] |
I dont think that CTR pistons would fit the b18 block, they would be a much smaller bore than the stock block.. Your taking pistons out of a 1.6l block and trying to throw them into a 1.8L block. I cant see how that would work. |
| Author: | urbanracer2000 [ October 08, 2005 ] |
They are both 81mm bore, the displacement comes from deck height, you would have to get the rods machined. Why are you doing this??? What is your goal?? |
| Author: | Nikku [ October 08, 2005 ] |
correct about the bore, however the displacement does not come from the deck height, it comes from the stroke, rod length, and a few other determining factors. Case and point is that the B20 has the same deck height as the b18a/b, but a larger bore. the b16a and the b17a also have the same deck height |
So you are saying the B16 and B18 have the same deck height...... 7mm diff If you wanna get technical, yes it also depends on the rod/stroke ratio being longer in the B18 |
no, i didnt say that, but also if you notice the b16B and the B18C have the same deck height, so in that case YES they do have the same deck height |
| Author: | kotomile [ October 08, 2005 ] |
temp said the b16a and b17a have the same deck height, but that the B20 has the same deck height as the B18A/B (LS). And yes for those of you who aren't aware the B16B is a de-stroked B18C |
tee hee |
| Author: | Hercules [ October 28, 2005 ] |
use the ctr pistons, get your rods machined and shot peened w/ arp rod bolts |
