why wont my axle go in :( ???
_drew
80% ricer
Post by _drew » June 28, 2005
car is a 92 dx hatch. Motor is from a 95 cx.
passenger axle went in fine, smooth like butta.
drivers axle goes in motor side just fine, but wont fit through the hub/spindle side.
it seems like its too large, gets about 1/10th of the way in, and just flat out stops.
tried a ton of wd40, motor oil, penetrating oil.. you name it to lube it up, but that little bitch wont go in.
all the ''threads'' look fine, nothing is chewed up on either the hub/spindle or the end of the axle....
help ???
[center:b7664ec607]Image[/center:b7664ec607]
popeye
Post by popeye » June 28, 2005
which axles are you using DX or CX??
_drew
80% ricer
cx axles.
will that matter? why would the passenger side go in, but the drivers wouldnt.
i hate life :roll:
TRAVASS
10% JDM
Post by TRAVASS » June 28, 2005
hit that bitch with a rubber mallet and a 2x4! always wrked on mine! sorry if thats no help!
kha
Post by kha » June 29, 2005
sweet talk your tranny first
Hercules
Post by Hercules » June 29, 2005
lol just make that sucker go in...try a different d-series axle if you can get one and see if that will work. if not there has to be somthing interfering in your hub or somthin. or just try cleanin out the spines real good too, good luck man
miyagi
Post by miyagi » June 30, 2005
clean out the spines really well, and just force the fucker in there - they're a pain in the ass sometimes ... especially on an older car..... but it'll go. a deadblow hammer and some sheer force will do the trick ..... and sweet talking your tranny and caressing it in the right spots doesn't hurt either. Good luck!
1990 Accord EX Sedan
All stock, All the time
money in the baaaank
Post by .saint » July 02, 2005
yeah maybe lube up your finger and slip it in the hole a lil. talk dirty get that hole wet should slip in a lil maybe use some force show the hole who's boss around there.
