LS Vtec
Builtb18b1
LS Vtec
Post by Builtb18b1 » September 02, 2009
I built an LS Vtec in march of 2008 using a b18b1 bottom end and a b18c1 top end. Until now I have had no problems with anything. Then last saturday night i was crusing in 5th gear and it just suddenly lacked pewer. It still runs but it misses real bad. I took the valve cover off and checked the cams and timing and everything seems fine. Does anyone have any suggestions?
Re: LS Vtec
Post by munster » September 03, 2009
I would check distributor cap, rotor, and plug wires. Just to rule that out too.
Builtb18b1
Re: LS Vtec
Post by Builtb18b1 » September 04, 2009
I did a compression check today and cylinders 1,3,4 are fine and cylinder 2 had no compression what so ever.
Re: LS Vtec
Post by munster » September 04, 2009
Ok. There's a problem.
jdm delivery
Re: LS Vtec
Post by jdm delivery » September 05, 2009
rings?
Builtb18b1
Re: LS Vtec
Post by Builtb18b1 » September 12, 2009
I finnaly got around to pulling the head today to find a hole in an exhaust valve.
Builtb18b1
Re: LS Vtec
I'm doing some research on valvetrain. Does anyone have any suggestions or recomendations on which company to go with? Right now I'm looking into crower and skunk2.
Jams_ek
Re: LS Vtec
Post by Jams_ek » September 12, 2009
crower is always a good option
Re: LS Vtec
Post by munster » September 13, 2009
Why not just do a Type R valvetrain?
Zero
Re: LS Vtec
Post by Zero » September 13, 2009
^^ yeah thats what id suggest.
