Transmission Help
ap_red97ek
Transmission Help
Post by ap_red97ek » June 19, 2009
So i didnt know where to post this because i just realized there really isnt an area to talk about transmissions and drivetrain so, if you want to put it where is should be .saint go ahead...
...anyway, here is the problem i'm having. I thick my clutch its starting to go and probably need to be replaced. It started acting up wednesday night after work. Its find when i pull out and i'm driving at a constant pace but as soon as i let off to slow down or make a turn to can feel as though it has come out of gear(but it really hasnt) and then when i give it some gas there is a delay where it is like its in neutral and then catches and goes. It did this alday thursrday as well and then thursday night it stopped and did not do it again this morning. Any thoughts on what you guys think it might be? I think its just my clutch is worn down and starting to slip and needs replaced.
If i could get some opinions on this ASAP that would be great
jdm delivery
Re: Transmission Help
Post by jdm delivery » June 19, 2009
take it to a garage. fuck transmissions.
Post by tenchu » June 19, 2009
manual i assume right? is it hydrolic or cable? if is hydro check the fluid, cable make sure the cable is tight. otherwise, sounds to me like your clutch is goin bad. how many miles? any mods?
ap_red97ek
tenchu wrote:manual i assume right? is it hydrolic or cable? if is hydro check the fluid, cable make sure the cable is tight. otherwise, sounds to me like your clutch is goin bad. how many miles? any mods?
yes is manual. hydrolic. there are 112,500 miles on it. its a 1997. no big mods, just exhaust, header, and intake. thats about it performance wise.
With that many miles theres a good chance it could be the clutch especially if its stock.
ap_red97ek
yeah i have had the car for about five years now and have not replaced it since i've owed the car. it also need a throw out bearing so i'm just have a new clutch kit installed
jdm delivery
stop it on level ground and try to pull out in second gear. if its hard for the car to move then you probably need a new clutch
moved to tech. jon u may want to add a drivetrain section?
Zero
Post by Zero » June 19, 2009
i was gonna say i had my single cam clutch for years. it went on three different D16y8s and two Ex transmissions and i never had a problem with my stock clutch O_O yeah i wore down but it still engaged.
Post by .saint » June 19, 2009
fixed the forums.
as far as the slipping, sounds like a clutch to me.
