Engine not statrting
https://thejdm.com/forum/viewtopic.php?f=17&t=10527
Author:  tomoyasu [ March 23, 2009 ]
Post subject:  Engine not statrting
my car seems to not be getting any power to the starter. when i try starting it all other electrical equipment works. i didnt see any ECU codes flashing, and the blinker lights on the gauge cluster go on as well. this all started when i replaced the battery.
help please!!
Author:  .saint [ March 23, 2009 ]
Post subject:  Re: Engine not statrting
all your grounds good?
checked and they all seem to be in order. we can get it to start by hooking a power source directly to the starter, but no luck beyond that.
check the fuses/relay?
Author:  munster [ March 23, 2009 ]
.saint wrote:check the fuses/relay?
Agreed. If the starter isn't bad I would look at the fuses.
Author:  tomoyasu [ April 07, 2009 ]
starter is good. fuses good. grounds all seem to be good. not sure what to check for with the relay.
i get a CEL. sometimes it just blinks once and goes off(happens the most), sometimes constant red light, and sometimes it will blink repeatedly 5-7 times and then go constant. checked with volt meter and im getting good reading the starter.
dunno what to do :(
Author:  .saint [ April 07, 2009 ]
did u do the paperclip in the plug trick to try and see what code you are throwing?
http://technet.ff-squad.com/how-to/celcheck/
Author:  tomoyasu [ April 08, 2009 ]
well ,got it started by hooking a power source directly to the starter.
also, my reverse lights stay on....
weird shit, i wish the wiring wasnt completely retarded
