cars not workin
tomoyasu
Post by tomoyasu » March 18, 2008
actually, i dunno now. just went and checked stuff out, sounded like it was just constantly buzzing for about a min, then stopped. when i turn my hazards on, my temp gauge goes up...the last time i had it running i drove it to my bros, all the gauges quit working, i was unable to go above 3300 (ECU is programmed for a 3300 rpm launch..dunno if that means anything) and it was bogging real bad..but when i started turning shit off, ( lioghts, cd player) it didnt bog down as much
Teaks92HB
Post by Teaks92HB » March 18, 2008
when my guages took a shit i had no turn signals but did have hazards. here my fuse for my back up lights went.. dunno why it affected but it did. a honestly forget when my car wouldn't go above a set rpm what it was.. you can always pull your plugs see how they look. if it was bogging bad, could be fuel, so i would try replacing the main relay with a known good.
Post by Nikku » March 18, 2008
how did you check the main relay? (like what process did you use)
have you tried putting in a different ECU?
tomoyasu
Post by tomoyasu » March 19, 2008
i disconnected it, checked if the wires/ connectors were bad, hooked it up. then, i read that if its working properly, it will click twice, the clicks being close together.
i dont have a spare ECU to use
tomoyasu
Post by tomoyasu » March 28, 2008
i got a different main relay today, still not working.
Post by .saint » March 28, 2008
damn. still nothing?
tomoyasu
Post by tomoyasu » March 29, 2008
yeah man. what could it be..ECU?
Post by .saint » March 29, 2008
the cabin gets juice but the motor dont?
have you checked your wires to make sure there is no splice or anything in any of the wires making a short?
tomoyasu
Post by tomoyasu » April 06, 2008
so im getting fuel as far up as the fuel rail...
Post by boostjunkie95 » April 07, 2008
what about spark?
