Let the debate begin
https://thejdm.com/forum/viewtopic.php?f=16&t=4493
Page 1 of 3
Author:  mr.green [ August 18, 2005 ]
Post subject:  Let the debate begin
What do you guys think I should put into my chassis once its finished at the shop?
1) A built LSVTEC with boost
2)A K20 with TODA internals N/A
Both will be near the same price doing the preliminary math. So lets hear everyones opinions.
Author:  Sean @ NDF [ August 18, 2005 ]
a built ls/vtec with boost will be no where near as expensive as a k20...and you would go with the boosted b series if your smart. :)
Author:  tenchu [ August 18, 2005 ]
Depends what your going to use it for. Boosted B on a road track = teh sucks. But on the strip, teh win!
Author:  munster [ August 18, 2005 ]
Boosted B.
boosted b on the track wouldnt be the suck...depends on what turbo actually.
My setup would be damn good for road racing, because it spool rather quickly, and I would be staying in the 4-5grand range anyway so I would always be ready to boost...
Author:  munster [ August 19, 2005 ]
Both setups would run strong. I would just go turbo because you'll be able to set higher goals safely. Are you planning on bore and sleeve too?
Author:  mr.green [ August 20, 2005 ]
yes, FULLY built. The costs would be VERY close for all I would want to put into the B block. vs. the cost of a nearly stock K engine with the head upgrade and ECU.
Author:  ls.pwrd.hb. [ August 20, 2005 ]
well a fully built ls on boost is going to generat more power than an all motor k depending on how far you push it
Author:  munster [ August 21, 2005 ]
84mm ls/vtec + GT series turbo = Fun.
Author:  BRYCE [ August 21, 2005 ]
K20! NA All the way! will be the best all around.
