h22 in a ef?
fourth generation civic & crx tech. [84-91]
Moderator: Nikku
90hatch
h22 in a ef?
Post by 90hatch » January 06, 2005
hey i want to do an h22 swap. does anyone know of anyone that has done it in a hatch or crx. im mostlikely goin to do it. il lhave the motor next month. but i want to talk to somone that has. shoot me in the right direction with pointers and shit. thanks
ur arms to short to box with god
Post by hondalowlow » January 07, 2005
1st youll need to pull the motor then get a 10lb sledge hammer to pound int he driver side lower fender well.. due to the alt hitting.. once u fight with that and get it bent it.. you cant cut it out due to the structurell support for the front end. go on ebay and get hasport
88-91 h22a mounts there around 300 bucks and your shifr linkages will need mod. you cnat use the prelude linkageds due to the lenght but u can use half and half.. half civic and half lude.. thats all i know.. and for wiring goes. i an't got a dam clue on what tha requires.. i got a h22a swap comming up soon in a EG hatch but when i do that i can give u some pointers.. good luck...
Re: h22 in a ef?
Post by kotomile » January 07, 2005
90hatch wrote:hey i want to do an h22 swap.
You do realize that this swap will make your EF an all-drag, understeering, noseheavy pig, right?
It will require loads more effort than a B swap and won't necessarily be any faster. A B with the same amount of $$ into it will run circles around an H22 swap. Hell, at the local dragstrip I've beaten several H22 swapped Hondas with my lil old B16A CRX!
Not meaning to flame I just want you to realize what you're getting yourself into.
Post by hondalowlow » January 10, 2005
yea dude... its gona be a money pit.. and if you corner fast on back roads its not gonna be pretty with a nose heavy car.. B sires all the way
Post by Nikku » January 11, 2005
hondalowlow wrote:yea dude... its gona be a money pit.. and if you corner fast on back roads its not gonna be pretty with a nose heavy car.. B sires all the way
my CRX w/ B-series was a money pit too :? 8)
