1st time at the dyno
https://thejdm.com/forum/viewtopic.php?f=15&t=73
Page 1 of 3
Author:  SikofFalln [ March 18, 2003 ]
Post subject:  1st time at the dyno
hit 125.3hp and 95.4tq at 7200rpm.
This was with a B16A2 with a hiper exhaust, race cat, AEM cold air, and a DC 4-1 header while running on a stock unchipped P28. It was better then I thought it would be with the ECU being stock and all. My A/F is really shitty before it hits V-tech.
Author:  domoMKIV [ March 18, 2003 ]
those numbers seem pretty low for being modded.....
vtec ;)
Modded yes, but running a stock SOHC ecu on a B16.
Author:  MagillaGorilla [ August 07, 2003 ]
Get your AFR straightened out and you will make a bit more hp/ft.
Or buy a LS block, yummm. :2:
Author:  mugen85r [ August 07, 2003 ]
b16a2 makes
160 @7600 rpm
so if you put in the b-series ECU for this engine, what numbers do you think you'll get???
that's a pretty big loss at the wheel for the SOHC ECU
Thats at the flywheel. You lose so much Hpgoing thorugh the drivetrain and wheels its crazy. Iv seen wrose numbers come from a b16 so atleast hes doin somethign right haha. :P
Author:  munster [ August 07, 2003 ]
Does anyone know what the hp difference would be if he ran a GSR ECU?
It wouldnt be too much. Maybe 5-10 HP max, the Vtec crossover is probably lower too.
Author:  Turbogixxer [ August 07, 2003 ]
I think that you will gain more (than people think) by a chipped p28, or a p30, p72. You car is probaby running lean. BTW did you scan the dyno sheet?
Author:  sal_blkej2 [ August 08, 2003 ]
wrd, get your p28 chipped then dyno it to see exactly how much you gain...i'm interested to know cuz i have a friend with the same mods as you except he has the skunk2 chip on his p28...lmk and good luck
