| Spnfedeg6 build FINALLY completed!! PICS INSIDE!! https://thejdm.com/forum/viewtopic.php?f=15&t=10859 |
Page 1 of 4 |
| Author: | spnfedeg6 [ June 26, 2010 ] |
| Post subject: | Spnfedeg6 build FINALLY completed!! PICS INSIDE!! |
Well I never started a build thread or anything like that but here is what Ive been building for the past eight years. LMK what you guys think. 1992 Civic Si / 178,000 miles Engine/Tucked/Bay mods: -Engine: B18c Jdm block, GSR rods, GSR crank shaft, arp rod bolts, fully balanced and blueprinted bottom end -JDM GSR LSD transmission -Exedy Lightweight flywheel and Stage1 clutch -Spoon Sports P72 ITR pistons .25 overbore -Spoon Sports high tension ground plug wires -Spoon Sports carbon kevlar plug wire cover - Mugen baffle oil pan -B16A PR3 head, fully ported and polished -Bronzed valve guides -Skunk2 stage 2 cams -Skunk2 adjustable cam gears -Skunk2 high compression valves -Portflow titanium retainers and valve springs -Skunk2 intake manifold powder coated silver -Hondata intake heat shield gasket -Edelbrock 65mm TB -Greddy timing belt, ITR water pump and oil pump -Chasebays tucked fuel lines -RC engineering 310cc injectors -AEM black fuel rail w/ black pressure regulator and Marshall liquid filled fuel press gauge -Walbro 255 fuel pump -Mugen 4-1 header - Omni power 2.5” test pipe -T1R B-Pipe -Mugen twin loop muffler -AEM Hybrid cold air intake -Shaved valve cover powder coated -Hasport polished motor mounts/ deleted A/C bracket and trans brackets -Blackworks Racing rad hoses -Fluidyne polished dual core radiator -Mugen thermostat and thermo switch -Spoon Sports plug wires w/ S2K platinum plugs -Engine management is Hondata S200 -Vision hood dampers -Boltboys/DownstarInc. Stainless bolt kit -Rywire Mil Spec Harness w/ labels -Tucked headlight harnesses -Chasebays Brake Booster delete w/ Wilwood master cylinder -Chasebays Brakeline tuck flex lines -Chasebays black tucked clutch line -Chasebays ground kit -Custom welded/shaved/smoothed engine bay with no seams Exterior/Body: -JDM EG6 headlights -JDM Vision corner lights (smoked) -JDM EG6 taillights -JDM EG6 Stanley yellow fog lights -JDM EG6 thin side moldings -JDM EG6 Bronze glass all window except windshied -JDM EG6 Door visors -JDM EG6 mud guards -JDM EG6 side markers -JDM EG6 Civic SIR-S badging -JDM EG6 hood nose bra -New wiper cowl and molding -New OEM windshield -New Front and Rear bumpers -All New exterior moldings/side skirts replaced with OEM parts -Mugen front lip spoiler -Mugen plate bolts -Vision carbon fiber mirrors -Spoon sports duckbill spoiler -Full paint job by Dave at Hableib Auto Body Suspension/Brake: -Function Form type2 coilovers -Spoon Sports Fr. upper strut brace -Spoon Sports R. upper strut brace -Skunk2 front upper camber arms powder coated Black w/ new version ball joints -Hardrace roll center adjusters -Hardrace front lower control arm bushings -Suspension Techniques front and rear sway bars -Skunk2 rear camber arms -Spc rear heim joint toe adjusters -Prothane trailing arm bushings -Function7 rear lower control arms -ASR sub frame brace -Front upper sub frame brace off ITR -All suspension components in front powder coated wet black -All rear suspension components in rear powder coated fine textured black -Manual steering rack conversion from a Del Sol -New OEM wheel bearings Front and Rear -Blackworks Racing extended wheel studs and lug nuts -GSR front brake upgrade -Powerstop rotors front and rear -Powerstop race brake pads front and rear -Powdercoated calipers front and rear (Gold) -Goodridge stainless braided brake lines Wheels/Tires: Mugen MF10L 15x7 +40 offset wrapped in Bridstone Potenza tires 205/50/15 Interior: -USDM ITR front seats -JDM EG6 climate control -JDM EG6 clock -JDM EG6 foglight switch -JDM EG6 defrost switch -OEM optional center console -OEM floor mats -OEM optional rear speakers and grille kit -ITR shift boot -Mugen pedals -Mugen shift knob -Alpine cd player with I pod attachment -Alpine speakers front and rear -Rear seat delete kit -Battery relocation under rear seat delete/Odyssey battery and bracket -15” full size spare tire under rear seat delete -Both front seat belts replaced with brand new Honda belts
| Author: | ap_red97ek [ June 26, 2010 ] |
| Post subject: | Re: Spnfedeg6 build FINALLY completed!! PICS INSIDE!! |
saw this car in person tonight. very nice |
Cool man where did you see it at? |
| Author: | Wax_Hands [ June 27, 2010 ] |
Very clean, nice work. This car has Wax_Hands approval...that means a lot too! :p |
| Author: | tenchu [ June 27, 2010 ] |
holy fucking firewall!! nice!! |
| Author: | spnfedeg6 [ June 27, 2010 ] |
thanks alot guys!! |
| Author: | Jams_ek [ June 27, 2010 ] |
nice bro the bay looks amazing!!! |
thanks again! |
| Author: | ap_red97ek [ June 27, 2010 ] |
I saw it in irwin at the car cruise. I checked it out while i was there. I drove by when i was leaving, i was in the blue WRX |
| Author: | .saint [ June 27, 2010 ] |
so incredibly clean. jaw dropping steve! car looks incredible! so how are the brakes since the booster delete? |
| All times are UTC-04:00 | Page 1 of 4 |
