D16 question
https://thejdm.com/forum/viewtopic.php?f=14&t=7718
Author:  Zero [ January 15, 2007 ]
Post subject:  D16 question
what is interchangeable on these engines? i mean between a non-vtec to a vtec... there is a good chance i need to rebuild the bottom end of my car and im looking for oem parts that would work... i would perfer it over putting a new engine in again... any experience or help is greatly appretiated... im just trying to get the car back into a good condition... damn it why of all times did this have to happen...
Author:  tenchu [ January 15, 2007 ]
I'm sure pretty much anything. Lots of factors to consider though, like OBD and what not. Also, is your car wired for vtec? If not, you'll need to change the wiring harness. IMO just try and find a low mileage d16y7 out of a 96-00 DX, they are cheap, and stout, just make sure you keep an eye on the oil.. It is a Honda. But i'll away have respect for the y7, mine took quite a lot of boosted beating, with very rare oil changes (back in my poor days).
Author:  SingleCamEJ8 [ January 15, 2007 ]
you can get a d16y8 for a few hundred bucks...you just gotta look.
the way i see it is if your gonna spend all this money on oem parts...you could get a complete low mileage motor(just the motor since you dont need anything else becuase the EX's come with the D16y8 ) anyway... find a salvage yard around your area they can be a gold mine if they let you search it.
:up:
Author:  hondalowlow [ January 16, 2007 ]
Zero wrote:what is interchangeable on these engines? i mean between a non-vtec to a vtec... there is a good chance i need to rebuild the bottom end of my car and im looking for oem parts that would work... i would perfer it over putting a new engine in again... any experience or help is greatly appretiated... im just trying to get the car back into a good condition... damn it why of all times did this have to happen...
ok since i speiclize in d16;s
you can use the y7 crank in a y8 as for y8 in y7
rods y7,y8 are interchangable
all d16 main,rod bearings r the same
heads. y7,y8 interchaneable
water pumps same
oil pans same.
all d16 engine part r the same except rod stroke and z6/y8 cams.
any other questions please pm me.
PS: ebay is your friend.
i got a set of y8 pistons and rods 40k on them ill sell. cheap
Author:  SingleCamEJ8 [ January 17, 2007 ]
good stuff man :up:
Author:  Zero [ January 17, 2007 ]
well the reason i asked was considering theis is the second time ive done this i was considering a mini me d series build... my current engine is from the Ex model and i was thinking it would be way cheaper to get a Lx motor then the Ex motor... either way it needs to get fixed no matter how its done but if i were to do the mini me i wouldnt have to wire anything as it already has everything in it...
Author:  tenchu [ January 17, 2007 ]
LX = D15
mini me would be kinda cool.
well what ever the non-vtec motor is from a 99 civic...
d16y7
