| need a run down on swaping a b18b1 https://thejdm.com/forum/viewtopic.php?f=14&t=6579 |
| Author: | vtjdmsir [ June 29, 2006 ] |
| Post subject: | need a run down on swaping a b18b1 |
i have a 96 civic hatch getting a b18b1 obd1 i hope 3 weeks just need to find out what ecu to use what i need to wire and what ever i might need to know Thanks |
| Author: | munster [ June 29, 2006 ] |
Same swap we did in mine. You're going to have to splice alot of wires since the plugs are different. Injectors, etc. You're also going to have to wire for a 2wire iacv. The third wire is just going to an empty pin. The major thing is that you're going to need to get an obd2 distributor or use the internals from your Dseries (what we did). Because your obd2 has the crank position sensor in the distributor rather than on the crank pulley side of the block like the obd1. As far as an ecu get a jumper harness and use an obd1 LS ecu (p75 I believe?) http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg http://www.ff-squad.com/tech/wiring/ It's been a while since I did it, so I can't remember alot of the details. I just remember alot of soldering. |
| Author: | vtjdmsir [ July 03, 2006 ] |
how do i switch the the crank sensor |
| Author: | vtjdmsir [ July 04, 2006 ] |
can i use a obd2 dizzy |
| Author: | mcmBuilt [ July 04, 2006 ] |
You can get a harness already done from Hasport if you don't want to splice it yourself, If not you'll need an OB2 dist. like Munster said, also an OB2 alternator, and you can get OB2 injectors insted of splicing your old ones too........................ I did the opposite, my car is OB1 and I put an OB2 B16 with a P28 in it.......GOOD LUCK !!! |
| Author: | munster [ July 04, 2006 ] |
You don't have to switch anything if you use the obd2 distributor. You'll just have a sensor going to nowhere hanging on teh side of your block (like mine) |
| Author: | vtjdmsir [ August 12, 2006 ] |
so if i switch all that all i well have to do is get a jumper harness |
