b20 swap
https://thejdm.com/forum/viewtopic.php?f=14&t=6457
Author:  vtjdmsir [ June 13, 2006 ]
Post subject:  b20 swap
I got 2 questions im thinking about a b20 swap in my ek now that my b16 is junk. The b20 is it a direct plug in swap and do i have to swap the intake manifold.
Author:  EK29K [ August 10, 2006 ]
i think so i don't think the b20 manifold will clear...almost positive....i am hoping to do the same soon
Author:  CivicSpoon [ August 10, 2006 ]
I'm pretty sure it won't fit either, it sticks up very high. But you should swap it out for something better anyways, even a B18b manifold will be better.
Author:  vtjdmsir [ August 12, 2006 ]
so it is a plug in play swap im getting a blox itm
Author:  SingleCamEJ8 [ August 12, 2006 ]
my homie has a B20 with a GSR head in his 99 hatch....and it gets up real nice :up:
GL with the swap.
Author:  Jams_ek [ June 10, 2008 ]
sorry guys but I don't know much about th b20's how much HP do they have stock and are the other b series better or worse both my civics are b16 and d16y8 both are ek's and I thought about putting the b20 in instead of the d16y8
Author:  peterbilt [ March 19, 2009 ]
Post subject:  Re: b20 swap
haven't done it myself
but ive heard the cylinder walls dont hold up with a vtec head like an LS would
Author:  kotomile [ March 19, 2009 ]
Post subject:  Re:
Jams_ek wrote:sorry guys but I don't know much about th b20's how much HP do they have stock and are the other b series better or worse both my civics are b16 and d16y8 both are ek's and I thought about putting the b20 in instead of the d16y8
It depends what you want to do with it, there are advantages and disadvantages to consider
adv-
*torque/displacement
*lighter block than B18
*cheap
*plentiful
dis-
*weak bottom end (6mm cylinder walls vs. 9mm, which is why the B20 is lighter, and also why the upper cylinders like to crack in boosted/CRVTEC applications)
*classified as a truck engine in most states, can cause you to fail vehicle inspection if they care to check
*swapping IM to clear hood
