Sway bar install?
99excoupe
Sway bar install?
Post by 99excoupe » October 24, 2003
How hard is it to install an SRR swaybar tie bar, and control arms? *cough john*? Am I better off with a progress bar?
Kouki EJ8 with camber issues....
Post by .saint » October 24, 2003
its not hard at all..jack the back of the car up. (both sides) throw on jackstands..
pb blaster the 2 bolts that hold the LCA to the subframe in the back. gets rid of the grime and loosens up any rust.. take those 2 bolts out and bolt up the srr tie mounts.. slide the tie bar in and use an allen wrench to tighten the bolts..
next slap the hardware on the sway bar and slide it up under the car. bolt the 2 tie ends down to your LCA's and slide the gubber gromments over the sway and line the holes up with the holes on the tie brackets. put all bolts in. tighten. lower car. and your done..
sorry that was such a quick how-to ill explain more in depth later if u need me 2.
