| vitara pistons https://thejdm.com/forum/viewtopic.php?f=14&t=10641 |
| Author: | idreamidrive [ June 23, 2009 ] |
| Post subject: | vitara pistons |
how fucked up would my sohc run if i ran vitara pistons in my engine before going turbo. i need to pass emissions next month and i am trying to get my engine built before then but also maybe want to go turbo. its just up in the air right now. stupid rod knock. |
| Author: | Zero [ June 23, 2009 ] |
| Post subject: | Re: vitara pistons |
well your compression is going to drop significantly but if you tune it right i dont see why it wouldnt run right. |
| Author: | boostjunkie95 [ June 23, 2009 ] |
You would lose a little power because of the lower compression, thats about it, it would run perfectly fine otherwise. Vitara's compression ratio is 8.5:1, stock pistons are around 9.2:1 i believe, not that huge of a gap. You could always have a few thousands milled off of your head to compensate if your that worried about it. |
| Author: | Sean @ NDF [ June 24, 2009 ] |
You will throw a cel. Probably triggered by o2 sensor |
| Author: | jdm delivery [ June 24, 2009 ] |
why havent you killed yourself yet? lolololol j/k long time no post! |
| Author: | idreamidrive [ June 24, 2009 ] |
will throw one or probably? i dont understand emissions and internal shit |
| Author: | Sean @ NDF [ June 25, 2009 ] |
Incorrect fuel burn. However, I passed with mine. I just unplugged my ecu right before he tested it so the cel went away temporarily. |
| Author: | .saint [ June 25, 2009 ] |
pull the cel bulb. |
| Author: | Sean @ NDF [ June 27, 2009 ] |
In Cali, they plug the machine right into the computer. pulling light bulbs doesn't work. the cel will show up anyway |
| Author: | .saint [ June 27, 2009 ] |
ah, bummer. |
