| Koni install...Cutting stock housing...? *help* https://thejdm.com/forum/viewtopic.php?f=13&t=4227 |
| Author: | Cascino [ July 07, 2005 ] |
| Post subject: | Koni install...Cutting stock housing...? *help* |
Has anyone ever had to cut 40mm off of your stock strut housing to get the Konis to fit? |
| Author: | .saint [ July 07, 2005 ] |
weird. |
ya its an em thing...u have to cut 40mm off the top of it, take out the factory struts(internals) and drop in the konis. |
| Author: | tommybanzai [ July 08, 2005 ] |
talk to ihavemorecarbonfiberthanyou (or however you spell that) , he would know. i never heard of that before...and i'd be 100% sure before i started hacking |
| Author: | .saint [ July 10, 2005 ] |
yeah i agree with tommy but your not going to be able to get ahold of knepper no more thanks to his 10+ 'hi' posts he is gone. i dunno what his deal is.. i never heard of cutting a strut before and honestly that dont sound right at all koni makes parts that are direct plug and play. if it involves cutting a strut or spring or anything of the sort i think you got a wrong part. expecially if it says 40MM and not like... 1/4 inch or something. |
| Author: | munster [ July 11, 2005 ] |
I never heard of cutting them. I wouldn't actually. As far as I know Knepper is still on stock anyhow. Just springs. For the reason that no one had struts made for the car at the time. |
| Author: | mr.green [ July 13, 2005 ] |
The Koni's are inserts for the original housing.... and are over priced as well for what you get. I've had Both Koni's and Tokico's and the later are much better IMO. Plus the Tokico's in this application come with the complete assembly brand new. You do have to cut/grind/dig out the factory cartridge. Send them back and buy tokico's. I have a lot of experience in EM chassis and used tokicos on them, very nice. |
| Author: | Cascino [ July 17, 2005 ] |
awesome, thank green |
| Author: | ls.pwrd.hb. [ July 17, 2005 ] |
thats weird as hell |
| Author: | centurioncivic [ September 27, 2005 ] |
yes that is right about cutting the strut housing. I know someone that did it and said its a big hassel and they have the tendency to rattle around once you drop the kponi down inside the stock strut housing. you must do this because koni didnt make the struts with a control arm(?) the arm thing that conects to your tie tod end, therfore having to use the stock. make sure you measure twice and only cut once because you dont wanna fuck it up. |
