| yo question for yall https://thejdm.com/forum/viewtopic.php?f=12&t=4519 |
| Author: | robry [ August 22, 2005 ] |
| Post subject: | yo question for yall |
sfc's car: okay the dude just moved and hes unable to get on the internet right now, still waiting for his cable to get installed. Anyhow, hes been having an ongoing issue with his 00 civic si, stock b16a2. Its surging at idle once hes at normal temp (180~F?) if hes sitting at a stop light, between 1500 and 2500 its surging badly. He got a CEL light and had the code pulled, and autozone said it was the IACV (idle air control valve ?). My main concern is if this is a common issue or if anyone knows anything to try and prove either way weither this is a concern or not. Let me know I'm sure he'll stop by the forums from work tomorrow. |
| Author: | munster [ August 22, 2005 ] |
I would change it just because of the annoyance. They're not expensive...I don't think. |
| Author: | tommybanzai [ August 22, 2005 ] |
could be a simple vaccum leak causing it too |
True. Tell him to check vacuum lines, but if that's not it...just pick up a new idle air. |
| Author: | tim_adams85 [ August 23, 2005 ] |
Well, before picking up a new one, try cleaning the one that's on there with some brake cleaner. That's done the job for a bunch of friends of mine. And do check the vaccuum lines for leaks. Good luck. |
| Author: | robry [ August 23, 2005 ] |
thanks I'll let him know. he said its only doing it while its hot, if he starts it up after it cools off, it doesn't do it, so my guess is its just the idle air. Thanks guys. |
| Author: | JDMcd8 [ August 23, 2005 ] |
I agree, would check that first.. |
| Author: | BRYCE [ August 23, 2005 ] |
mine used to do that then i replaced the fast idle sensor i think it was called |
