POST WHORES UNITE!!!!!!!!!!!!!!!!!!!!!!!!!
vent. relax. have fun. anything goes. off topic chit-chat.
Post by 77 » June 21, 2007
Sean @ ESG wrote:i dont get it, this is some wisconsin shit
Image Note the valve stem. It's not the rubber type, it has inner and outer o-rings, a retainer washer inside and then two nuts that lock. When installed it's rigid, not like a "normal" valve stem which you can push around.
It's cool, but there's zero info on how they work. No instructions with the wheel, nothing online. I should probably MS Paint an instructional diagram.
Post by BRYCE » June 21, 2007
haha you are so mechanical inclided.... common sense will tell you how to install it. and its nothing new all higher end rims come with them.
just make sure the rubber is seated in the inside of the lip and put all the nuts on the outside most likey. thats how enkie, works, and volks do it.
i thought you had enkies wtf is your problem.
hey speakin of which what sizes are your rpf1's i might be interested.
Post by Sean @ NDF » June 21, 2007
My NR-S' have metal valve stems...its not rocket science toby
Post by .saint » June 21, 2007
my advans dont have the rubbers. they are completely threaded.
SidewaysR1
Post by SidewaysR1 » June 21, 2007
My wheels also have the same valvestem setup. I guess its a japanese thing or something, havent seen them in the states. I guess its quantity over quality in this country.
idreamidrive
Post by idreamidrive » June 21, 2007
i see them mostly on truck rims at work
Signature
BRYCE wrote:haha you are so mechanical inclided.... common sense will tell you how to install it. and its nothing new all higher end rims come with them.
I've never encountered that before.
Looking at it it's fairly straight forward, but I'm a "better safe than sorry" sort of guy, so I went on the search for information supporting my idea.
I was also curious about torque specs, but, yeah, none.
Post by boostjunkie95 » June 22, 2007
SSR's have the same stem set-up. Snug the nut finger tight then go a full turn with a socket and your good to go.
Post by BRYCE » June 22, 2007
torque specs!!!! hahahahahahaah you retard!
idreamidrive
Post by idreamidrive » June 22, 2007
BRYCE wrote:torque specs!!!! hahahahahahaah you retard!
torque specs help you from snapping stuff off... like your differential carrier
