thejdm.com v3
the original tjdm.
Skip to content
2004 accord idle higher
accord & prelude all generations tech.
Postby robopat » May 12, 2010
hey ,I have a problem and I hope someone can help me.I had my car park for 5 month and I didn`t make it run regularly Now is back on the road but the idle is too high and is going up and down ,The gas tank was full .so I use a fuel system treatment and I cleaned the trottle body but i still get the 0507 code for idle higher then normal.With that code I can get the emmision inspection pass.Here in NY they are really tough with that.I hope somebody knows about this.Thanks.
robopat
Re: 2004 accord idle higher
Postby .saint » May 12, 2010
so im guessing the idle is fluxuating. its up then its down its up then its down like you are tapping the gas then off it then tapping again real quick? how high is it going?
[.saint works] is coming soon!
.saint, the rolling honda EK parts jdMuseum.
mac miller straight up kills it! poop.hell sideways.brigade
http://www.builtmotorsportswear.com
http://www.frightmarestudios.com
1999 Honda Civic
Highscores: 5
Postby robopat » May 13, 2010
it is going between 1&2 after a little bit stays in 2.Do you think pumping the old gas out would help?Thanks.
robopat
Postby .saint » May 17, 2010
eh. usually the gas wont have much effect on the idle like that.
i tried looking up the 0507 code but came up with nothing.
have u used the CEL flashing light trick?
http://www.ff-squad.com/technet/how-to/celcheck/
here is a list of CEL codes and obd2 "p" scanner codes. maybe i missed the 0507 code in the list but you can check.
http://www.ff-squad.com/technet/ecu.codes.htm
http://www.ff-squad.com/technet/ecu.codes-p.htm
1999 Honda Civic
Highscores: 5
Postby Jams_ek » May 17, 2010
its the sensor in your cat mine did it for a long time til I put my spoon sports cat on and my new sensor now its fine... I'd check that first
Jams_ek
2000 Honda Civic
Postby .saint » May 18, 2010
yeah i was thinking a dirty o2 sensor. its a hit or miss if it will throw a code. if its real bad it will.
1999 Honda Civic
Highscores: 5
Postby Jams_ek » May 19, 2010
well I didn't know but mine came unplugged lol
Jams_ek
2000 Honda Civic
Return to accord. prelude.
Who is online
Users browsing this forum: No registered users and 1 guest
